magnaflow question - FirebirdV6.com/CamaroV6.com Message Board
magnaflow question
  • magnaflow question
    is this everything i'll need for a LT1 magnaflow in my '99 3.8 maro?
    magnaflow 3" LT1 kit for a 97 maro
    a carsound universal short oval body 94100 series w/02 boss
    18" bullet resonater ( i dont need it but i heard it will make it sound even better)
    will i need anything else? like an S-pipe? and will that cat work?
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    looks good but check out graymans site at the top of the exhaust section. Bout the same as me and him have, sounds nice [img]smile.gif[/img]
    97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
      the LT1 magnaflow comes with an s pipe.
      you will need two extra 3" u-bolt clamps for the cat to s pipe/y pipe...until you get it welded.
      I used two universal hangers on each tali pipe. about 3 bucks each. real strong and no bouncy bouncy with two hangers. you can also use your stock v6 tail pipe hanger pins....if you feel like hacking them off and welding OR have new pin hooks made...but 12 bucks in universal hangers is real easy. I used the stock bolts and bolt holes on the undeside of fram rail...you will see...just remove the stock 'rubber' chassis mounted hanger. use those bolts and bolt holes to hang the tail pipes.
      I also have a full install guide for the magnaflow LT1 on my site.
      It sounds great but it is loud...even with the two mufflers. the bullet does cut down on the high end as well as the droning....but when you punch it is LOUD.
      12" universal oval cat. check if your car has a AIR TUBE on the cat before you order. I think your part number in first post is different than mine...it probably works...double check on my site if you like.
      good luck.
      01 Firebird A4 3.42
      Powerdyne @ 6 PSI
      and other mods
