LS-1 Lid - FirebirdV6.com/CamaroV6.com Message Board
LS-1 Lid
  • LS-1 Lid
    Just wondering if the LS-1 Lid will work on my 98 and if it does is it as effective. Theres more LS-1 lids to choose from and they are generally cheaper. Anyone using one?
    1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
    do a search.. same shizit gets posted every 10 days I swear. It won't fit unless you do modification on it, its way better just to get one made for your car.
    2002 Silver Metallic A4 Firebird - All Options
    Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
    Your Mom or My Dad?
      Not unless your running a blower. I tried back in the day. It doesn't work. [img]graemlins/thumbsdown.gif[/img]
      http://seppo.hopto.org/
        Thanks. I figured this was posted often but didn't find anything when I skimmed through.
          I have the LS1 lid on my car Direct flow lid from ls1motorsports. The v6 lid is probably better though because the outlet is more to the right and at a better angle to our throttle bodies. Got mine before I knew any better. I like it though because it's supposed to be of better construction than the whisper lid.
          <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
