intake+a/c duct=cold non humid air intake - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • #31
    find the grease fittings in your muffler bearings, they're located next to your knocker valves, you'll have to grease 'em up there.
    1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
    • #32
      i got my blinker fluid from
      http://www.kalecoauto.com/
      under maintanence
      while i was shopping i also picked up -Cross Drilled Brake Lines-
      • #33
        I needed a laugh for today... I think I found one...
        1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
        • #34
          blinker fluid contains some of the same stuff as sweet-n-sour sauce so you can actually use sweet-n-sour sauce for a temporary fix
          It\'s a beautiful life<br /><a href=\"http://www.cardomain.com/ride/2035163\" target=\"_blank\">http://www.cardomain.com/ride/2035163</a>
          • #35
            really?!! [img]graemlins/omg.gif[/img] hmm i think i have some of that. maybe my blinker will blink normaly now. :D
            • #36
              aaaannnnndddd if you use that fix and you forget to ask for it when you get chicken mcnuggets you can just pull over and dip it in the blinker fluid resiviour (spelling) i do it allll the time, it actually taste better because all the flashing lights give it a carribian style marinade
              • #37
                BAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!!!!!!!! :D :D :D :D : : [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                • #38
                  I just finished my caliperless brake mod. Took it down the street and back. Pedal felt a little mushy. Maybe i need some of the cross drilled brake lines
                  • #39
                    yep, you definatly need cross drilled lines, then the pedal will be nice and firm again. [img]graemlins/banana.gif[/img]
                    • #40
                      good weight reduction mod is to drain the blinker fluid (use hand-signals), and pull the engine and use the donkey/mule mod
                      3.73 gears ramair kit flowmaster is no more now BORLA cat-back 3\"catco cat<br />best et w/ flowmaster 14.8 best et w/ open borla 14.62@94mph :)best et w/ open borla and drag radials 14.4 at 96 o yea and a set of pacesetters
                      • #41
                        Originally posted by loser:
                        </font><blockquote>quote:</font><hr />Originally posted by xX315Xx:
                        that's cuz you didn't use any elbow grease. my exhaust rattles, i think it's my muffler bearings, they may need some elbow grease...
                        my cat rattles too. maybe ill need alot of that elbow grease when you drop it off. do i just smear it all over the cat? and tips will be very helpful. </font>[/QUOTE]just make sure you get it all over the cat. when properly done it should look somethign like this.
                        95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
                        • #42
                          thanks alot andrew.brandon, so just drench the cat really good? alright ill make sure it looks close to that.
                          • #43
                            </font><blockquote>quote:</font><hr />Originally posted by TheGreenPunisher:
                            yep, you definatly need cross drilled lines, then the pedal will be nice and firm again. [img]graemlins/banana.gif[/img] </font>[/QUOTE]You don't even need brakes, all they do is slow you down anyways.
                            2000 Mystic Teal Firebird<br />Full 3\" exhaust, FRA, Aluminum Driveshaft
                            • #44
                              From what i understand, if you get a Rugrats bandaid or spiderman or something along those lines, it actually helps you shift faster...
                              There aren't any Greddy bandaids?
                              • #45
                                There aren't any Greddy bandaids? </font>[/QUOTE]coulda sworn i saw NOS band-aids once....
