stupid question... i've read alot about the throttle body bypass on ls1.com for the ls1 engine 'n i just assumed that i could do the same on my car... i went out, got the parts, 'n then looked at my engine... TB bypass not quite possible on the 3.8L is it??? anyone else run into this? just checking... thanks!
You're talking about blocking the coolant flow to the tb, to keep it cooler, right?
The coolant flows through 2 small (pinkie size) passages in the intake, through a narrow channel in the tb that is connected to the 2 openings. The channel is fully open, the gasket forms one side of it.
Some people have put a custom gasket in there to block off the 2 passages. I filled up the channel in the tb with Devcon (its like JB Weld) and used the regular gasket. It still has the openings, but nothing can flow through the tb. The advantage of the custom gasket is ease of converting back. I would have to mill out the Devcon to convert back.
I left a tiny bit of the passage open, supposedly the design behind this is to keep the tb from icing in cold weather on startup, so I thought I'd keep a little of it.
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
