OK so i got my loudmouth. but the rear passenger side hanger, the plate with the 2 holes, i cant figure out how it is supposed to be. i lost the rubber hanger that was there b4. but does anyone have a pic of it and how it is supposed to be hooked up?
Need help loudmouth
Need help loudmouth
<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)Tags: None
well the y-pipe as you may know is 3 in. before the cat. so i cut the cat off, put a high flow one on thats 3in in/out($50 ebay). got a 3 in u-bent pipe from jegs($12) and it slid right on.
if your going to run the stock cat, which i would reccomend. then youll need a 2 1/4 adapter to 3in..<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
here you go, i hope these pics help. if this is not what you are talking about or if you need more/better pics just let me know and ill see what i can do.
i hope it works if not then ill try again when i get home from school.
http://pg.photos.yahoo.com/ph/newfou....net/my_photos
[ February 09, 2005, 05:10 PM: Message edited by: oh my Goth ]<a href=\"http://www.cardomain.com/id/ohmygoth\" target=\"_blank\">http://www.cardomain.com/id/ohmygoth</a>
thats what i needed thanks alot man! mine looks nothing like that though. i thought something wasnt right about mine. my hanger is one of the ones with the little rod (like the driver side one).
thanks again!<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
