How big is an exhaust on my 1996 camaro v6?
Inches?
Originally posted by Michael Sosebee:
what about before, i am looking at cutouts before the catMatt
1998 Mystic Teal Camaro M5
i am for hard stuff and saying i did it, i would have to cut the pipes? cause i can do that, i will also need to weld everything in? What kind of weld i can do tig mig and arc and oxy-accataline? what would i have to take off to weld everything in? Dificulty 1-10, i am 15 and have rebuilt my engine, so i have experance, like what can you tell me about all of this?
Thank you so much everyone whos helping me
personally i say just leave your egr in place, on an otherwise stock engine your not even going to be able to tell a difference. The egr system doesn't operate under WOT anyawy. Also if all you do is block off the egr system your PCM will set your SES light.
As for the cut out i would probably just MIG weld it in place directly before the cat. If you welded an O2 bung into the cutout pipe there will be enough room for it. But yes you will have to weld everything inthe black 97 <br /> New favorite Mods: Hptuners, and SLP 2OTL
Well what are you looking for because before the cat you are porbaly going to lose power. Its going to through an ses light without an o2 SIM not sensor.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
