has anyone tried straight pipes on a 3.8, i'm gonna cut off the flowmaster on my cat back, so other that the resonator that came with it i will be running straight through after the converter. any advice or sound clips from anyone?
straight pipes
I ran completly straight pipes for a while. It sounded like **** right after 2500 rpms. If i had a sound clip i would post it but i don't. also it was waaaaayyyyy loud.1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> <----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
suggest not 'cutting' the system...but rather disconect the section aftr the resonator and before the axle cross over. fire up the car. don't bother taking it off the jackstands...you will be back under there to reconect the rest of the system.
[img]smile.gif[/img]
