SLP LM 2000 Firebird V6 install questions... - FirebirdV6.com/CamaroV6.com Message Board
  • SLP LM 2000 Firebird V6 install questions...
    First off, Im new to the boards, so hello
    Im getting an SLP LM system for my 2000 Firebird, its just a V6 and later on Im hoping to install a turbo, but for now just small steps. My questions are:
    1. What comes in the installation package on sites that sell the SLP for V6 cars and do I need it?
    2. I want to do this install at a buddies house in a day, is there any welding required for this job or is it all bolt on for a 6?
    I just need detailed info on this, I cant find it on any forums and this seemed like a good one to ask on.
    TIA guys.
    2000 3800 II V6 Firebird<br />various small mods, bigger stuff later.
    It comes with clamps but dont use them, if your afraid of welding just let meinike do it for $100
    2000 Camaro, Pewter Metallic, M5 tranny, 3.23 gears, Hard Top, <br /><br />Modifications:<br />SLP loudmouth (dual/dual tips)<br />MSD 8.5mm wires<br />K&N airfilter<br />SS hood (don\'t buy from fiberglassfabricators.com!!!)<br />Spec stage 2 clutch
      Check my website in the sig for pics, i juss bought the system and had then make a fitting to attach it to the stock piping after s-pipe and i will replace it later when i get headers and cat.
      1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'s
        So dont get the install kit and just let a muffler shop take care of it?
        Think its possible to get it all on myself and then drive it over to be welded?
        Sorry for all the ?s, I just wanna make 100% sure I cant do this myself without welding, I wanted it to be a day project over at a buddies house. I love workin on this thing myself knowing that everything done so far on it was by me, this would be my biggest achievement.
          You can always search for these kind of topics as they have been talked about many times.
          1. the loudmouth is made for the 93-97 lt1 and 98-02 ls1. there isnt one for the v6. but as with many exhuast fior our cars, the v8 cat backs will fit on v6's.
          2. the cat back comes with an i pipe, y-pipe, pipes out the back, tips, and clamps.
          3. you will need to either get an adapter to go from 2 1/4(stock s-pipe size) in to 3 in.(loud mouth size). but there is another option, before you cat the pipe size is 3 in. but after the cat its bottlenecked to 2 1/4 in. so you can get a high flow cat 3in in/out($50 on ebay), get the l1t install kit from slp or make your own from a piece of u pipe but youll have to cut it and weld it. all you do is take the u pipe cut it in half flip one side up and weld it.
          the high flow cat is def the better route to go as it will improve both power and sound.
          the stock 2 1/4 s-pipe will give you a more ricey sound.
          you can def get it done in a day. it is bolt on, but if you can weld it as it helps prevent leaks.
          tools youll need:
          jack and stands or ramps( i only used them on the rear)
          socket and wrench
          sawzall or hacksaw
          recap on what you need:
          slp loud mouth cat back(got mine on ebay for 315 shipped)
          3in in/out high flow cat(ebay i suggest magnaflow)
          install kit i think part #30045(slponline.com $75)
          or
          u pipe madrel bent(jegs.com like $15)
          u-pipe
          or
          a 2 1/4 to 3 in adapter
            I think Ill get the cat, install kit and do this myself, I cant wait! Thanx for the info.
              good choice. youll love it! i just posted a video clip of mine in this forum if you want to check it out.
              http://www.camarov6.com/cgi-bin/ulti...sts;u=00005341
              edit: since your getting that cat youll need to cut the old one off. i used a sawzall.
                that link to the sound clip is dead, please repost
                2001 Pewter Camaro A4/Y87<br />--------------------<br />K&N Aircharger, SLP Cold Air Induction, Hypertech Programmer III, 160* thermostat, manual fan switch & just ordered 3\" SLP loudmouth system LIVE THE MAYHEM - <a href=\"http://www.collegemayhem.com\" target=\"_blank\">http://www.collegemayhem.com</a>
                  here ya go:
                  http://www.camarov6.com/ubb/ultimate...;f=25;t=006534
                  i just posted it today so you can also look in this section intake/exhaust its called "Loudmouth soundclip/vid"
                    One more ?
                    I know I have to cut off my old cat, but how do I get the new one on without welding?? or do I absolutely have to weld that piece?
                      This brings back memories from hacksawing my stock exhaust off... Man that sucked :-p
                      \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
                        it will just slip on and just clamp it. but use some heavy duty clamps, not the cheap 2 dollar ones from your local parts store. you can order them from jegs or maybe find them at an exhust shop. you only need 2. just make sure you make them tight.
                        lol i started mine before i had a sawzall too!
                          yeah, I have no Sawzall, so Im kinda scrwed, this ones gonna be a *****. On the good side of things I have a whole day to do this :)
                            lol good luck!
                              Just be happy you don't have true duals like mustangs bc then youd be cutting 2 pipes with a hack saw. I did that today [img]smile.gif[/img]
