i just installed my kit. while i was installing it, one of my filters fell off. i went in from the bottom to re intall the filter. my question is; can i just leave this plastic shroud off? would it help getting more air? or should i just leave it alone??
SLP cold air kit help
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
I personaly would leave it on but I remember reading something a while back about using the cold air intake system from SLP. What the person did was take some sheetmetal and make a scoop type thing and cut out a hole in the shroud thing and screw it on there. Altho I think that a lil extream but it does make since with what he did.
I made a scoop on mine also, That was short lived tho, it was ripped off. I don't think I ever did put the plastic peice back, you will be fine.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
