Well I have my carsound cat but can deceide how to install it. The stock cat has a metal bracket that appears to be bolted to the old cat or something, and then the spipe. Should I chop the Spipe off and weld it to the new cat and then what to do with that bracket thing? Anyone done this?
installing cat
um, I think the stock system is a welded cat on both ends. I don't remember a bracket. The stock s pipe has a band clamp to the mid pipe, though.
Are you just changing the cat? 3" to 2.25"?
If so, on mine...with the welded cat...cut the cat at the y pipe right up close to the cat weld line as possible. You new 3" in cat will slip over the y pipe. YOu can clamp it with u bolt and weld later if you like. (i like clamp...if cat goes bad I can just take it off rather than loose meat of the Y pipe everytime I need to cut it off)
Next, the 2.25" out collar of the cat will slip over the stock s pipe...do the same there and cut the cat off the s pipe as close to the weld line as possible.
the exhaust system design varies from year to year. stock exhausts have a bracket (attached to the rear of the cat) that mounts to the transmission x-member... that's why your exhaust seems to change note when you add a stiffer transmission mount.
a shop will probably make something that goes 3", fill with weld to 2.5", fill with weld to 2.25". not a very sweet way to do it but there isn't much other choice unless you go to a full 3" exhaust.
yes, your pipe is 2.25 so you'll need a reducer. nothing a shop cant do cheap
