I was undoing the manifolds and one of the studs that accepts a nut for the heat shield (drivers side top front) broke off. Its inside the hole on the engine. What can I do or am I screwed?
Started Header Install Major Problems
more than likely your screwed. unless its one of the ones where you stand some sort of chance of being able to get at it with an EZ out, but I kind of doubt the likelihood of that.\'01 Mineral Grey SVT Cobra<br />-former F-body owner
Originally posted by 2KThunder:
I was undoing the manifolds and one of the studs that accepts a nut for the heat shield (drivers side top front) broke off. Its inside the hole on the engine. What can I do or am I screwed?<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
It happen to me also when I took the head off. I used a EZ out. It might be a better idea to take the head off so you have less of a chance to break the ez out...then your screwed.<b><a href=\"http://www.cardomain.com/id/onebad9d5\" target=\"_blank\">1995 Red 3.4L Camaro</a><br /></b><br />Dont laugh if you see me pushing, no reverse, tranny needs rebuild.
Alright got the dipstickout and removed both manifolds. Turns out there is around 1/4 of an inch of the screw thread sticking out (it was covered by the manifold. What is this EZ Out? Cant seem to find info on it through google. We tried vice gribs but they wont hold. Anyone have any suggestions? Also, The pacesetter gaskets are not oval shaped like the stock ones, I can still use that gasket correct (the headers are not oval either). Thanks everyone for replies.
[ February 16, 2005, 10:15 PM: Message edited by: 2KThunder ]
Block off the hole on the header for the egr, trying to bend it and seal it completely is too much trouble, trust me I know from experience. I tore the valve off an took the piece that bolts it onto the header off the valve, hammered 2 dimes into it and some sealant stuff and bolted it on the header. No leaks [img]smile.gif[/img]\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Or just buy a blockoff plate. ;)
http://home.cfl.rr.com/mkaprocki/Camaro/EGR.jpgMatt
1998 Mystic Teal Camaro M5
doesnt the EGR help gas mileage though?
Originally posted by hockeyman:
Does it throw a code when the egr is deleted?Matt
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
