resistors with IAT - FirebirdV6.com/CamaroV6.com Message Board
resistors with IAT
  • resistors with IAT
    Hello everybody. I ran a search and found some info about putting a resistor in series with the IAT, but now have some questions about it. I know it advances your timing since it thinks the air temperature is colder, but does it lean or richen the mixture?
    A second question is just a subsidary one. I read a test and found that adding around 10K Ohms of resistance advances timing about 5*. Is this enough to have to use premium gas? Stock computers are programmed for regular, so i wouldnt want to trick the computer with too many things before I program it right.
    1996 white camaro M5<br />-Custom CAI, !MAF, !EGR, Hi-Flow Cat, Magnaflow Cat-back, Removed Jack/Spare/Back seats.<br /><br />2.12 60\' Best<br />15.14 @ 90 1/4 mile Best
    if you searched like you said, then you should realise that 3.8's tend to not see any gains with it, where as the 3.4's do. FYI
    as for your question, I don't know the answer lol
    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
      They go for about $0.15 over at radio shack. This guy should be smacked for selling these for so much!&gt;http://cgi.ebay.com/ebaymotors/ws/eB...954988899&rd=1
        I know. did mine myself, but I think im taking it out for these two reasons.
        1. It advances timing and since the intake air is warmer than the car thinks, you are risking detonation.
        2. It richens the mixture, and will have negative effects with the warm air that is coming in.
