Rattle in my muffler area - FirebirdV6.com/CamaroV6.com Message Board
  • Rattle in my muffler area
    Lately I noticed that there is a loud rattle in the muffler area at about 1100-1200 rpm. I searched some threads and the only solution they offered was to look for a loose heat shield. I did that and still can't find whats wrong. Anyone else have this problem and be able to fix it?
    Check the exhaust hangers. Make sure they're tight, and that the rubber inside isn't worn out. I had to replace one because the rubber was torn to crap from something...
    1997 Y87 Camaro with a motor and some stuff.
      look at the hangers and then check the cat for loose internals. I found my old cat was defective so I got a high flow Catco 3"
        Yup I recommend you check out your cat [img]graemlins/thumbsup.gif[/img]
          It doesn't sound like its coming from the cat area though....when it started rattling when I was behind the car i pushed down on the tips of the exhaust and it stopped and then started when i let up.
            Do you have tips that have bolts that screw into the pipe to secure them? If so, the tips are the culprit. I fixed mine by applying thread lock and then tightening them as much as i can.
            1997 Camaro 30th Anniversary...M5, chrome 16\" 5-stars Goodyear 245/50R16<p><a href=\"http://members.cardomain.com/issycamaroman\" target=\"_blank\">http://members.cardomain.com/issycamaroman</a>
              Well...I finally diagnosed the culprit...the cat seemed to be making the noise and transmitting it down the exhaust so I could hear it out the tips. It only does it when it starts up so I don't know what the problem is but I plan on gutting the cat anyway....I'm just waiting for my o2 sim.
                had the same problem, the dealer couldn't figure it out and kept replacing the y-pipe and cat...turns out it was the joint between the S pipe and the I pipe. Tighten that thing down with a clamp and your gonna be good to go.
                2000 Y87 Bird M5 with mods<p><a href=\"http://www.vzavenue.net/~ngeorg/\" target=\"_blank\">http://www.vzavenue.net/~ngeorg/</a>
                  <blockquote>quote:</font><hr>Originally posted by UNFNick2k:
                  Tighten that thing down with a clamp and your gonna be good to go.<hr></blockquote>
                  not pickin on you by quoting, but what's with everyone using bolt type catback systems. I just have the whole mofo welded together. Nothing will come loose and nothing will rattle (except my old def. cat and a broken hanger). [img]tongue.gif[/img]
                    I have EVERYTHING WELDED and i had my cat replaced last week cause ithought thats what it was... WASNT........ well i STILL have a ratlle somewere and i can not figure out where the he!! it is and its driving me nuts !!!!!! i know it has something to do with the rear hanger but i cant figure out what..... the rubber is fine. its TIGHT. its not hitting any heat shields. And it is going to cause me to go INSANE. [img]graemlins/crybaby.gif[/img] :rolleyes: :mad: :(
                    AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
                      <blockquote>quote:</font><hr> had the same problem, the dealer couldn't figure it out and kept replacing the y-pipe and cat...turns out it was the joint between the S pipe and the I pipe. Tighten that thing down with a clamp and your gonna be good to go. <hr></blockquote>
                      That seemed to fix it. We will see tomorrow if it is still fixed as it really only happened after sitting for a while. Thanks a ton.
