i got litte money left this moth and i wanted to buy something for my car has any body used this i am not look for a big gain in power just tring to get more miles on gas is it worth the 57bucks http://www.ftpp.net/V6Main.htm this is were i am buying from
MSD GM Coil Interface Module
94 3.4 camaro m5<br />mods-- B&M ripper shifter, TB bypass, <br />here\'s my vid-- <a href=\"http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0\" target=\"_blank\">http://video.ls1tech.com/Player.aspx?fileid=8E16D909-7766-41B1-BC2A-EBCCB9111EDD&term=3.4&p=0</a>Tags: None
The interface modules are designed for use with the MSD DIS-4 ignition module. They go between your coil pack and the ignition control module and make the installation/wiring of the DIS-4 easier. Without the DIS-4, they will serve no purpose.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
