Britney Spears is the HOTTest girl in the world!<br /><br />2000 Camaro 3.8L Y87<br />Flowmaster 80 American Thunder catback<br />Magnaflow Carsound Catalytic Converter<br />SLP Ram Air Cold Air Intake<br />Whisper Lid<br /> <a href=\"http://www.cardomain.com/id/freestylin59\" target=\"_blank\">http://www.cardomain.com/id/freestylin59</a>
\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
its not a hood, bubba. the slp intake goes under the hood and sucks air from the grille, thus moving into the K&N and giving you.. 6 for the k&n and lets say, 6-10 for the slp?
I have one of the k&n intakes. Part # 63-1084 It is similar to that one, but for some reason is not street legal because it is not CARB approved. No emissions checks around here so I got it. Put it on. I was impressed. It comes with a pretty nice metal heat shield. It sounds like a cold air intake. I am happy with it.
i have the set up your refering to. i have the k&n FIPK with the slp cold air induction. it is a GREAT combination. noticed alot of gains thru each mod. i did the k&n first, noticed much improvement, then had the slp cai put on, and it worked even better. the slp cai is cut right underneath where the k&n sits...so its perfect placement..the cold air is forced right into the filter. cut right into the heat shield that is supplied with the k&n kit to mount the slp kit, never had one problem with that set up. highly reccomended.
2001 Pewter Camaro A4/Y87<br />--------------------<br />K&N Aircharger, SLP Cold Air Induction, Hypertech Programmer III, 160* thermostat, manual fan switch & just ordered 3\" SLP loudmouth system LIVE THE MAYHEM - <a href=\"http://www.collegemayhem.com\" target=\"_blank\">http://www.collegemayhem.com</a>
