I would like to do it to mine. Was there any draw backs? Do you have instruction on how to do it?
Has anyone ever port and polish their TB?
A couple people here have done it, and I've seen a PDF posted with the instructions.
The general consensus is that it's not worth the trouble (tuning, etc), though.Matt
1998 Mystic Teal Camaro M5
I'm doing it at the moment. Biggest drawback... I was dumb and decided to polish the outside too. That's taking a while. The inside really wasn't that hard.
1) Cut through the I part with a hacksaw blade.
2) Use a dremmel tool to whittle down the extra pieces left.
3) Sand down with the cylinder sanding bits and a dremmel.
4) sand down by hand with 400 - 800 sandaper.
5) Polish up.
6) Most important! DO NOT polish the outside. It's a friggin pain in the ***!<a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
yea when this was talked about last time everyone pretty much said that tuning would be a problem and figuring out how to tune it with the sensor for the more air going through.
Originally posted by 97rs4life:
yea when this was talked about last time everyone pretty much said that tuning would be a problem and figuring out how to tune it with the sensor for the more air going through.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
DON"T DO IT.
I ****ed mine up when i did it. If you want to do something to it, take it off the car, clean it up with carberator cleaner, and then polish it with a cloth polishing disk on a dremel.
Its really not worth the trouble, our cars Throttle bodys can flow more air than the car can take in.1996 Pontiac Firebird<br />Flowmaster Exhaust, Custom Cold Air Intake, 3.42 gears with LSD
