larger tb on a 3.4 - FirebirdV6.com/CamaroV6.com Message Board
larger tb on a 3.4
  • larger tb on a 3.4
    I am planning to go FI this winter and am looking at the prep mods to do so. I know a larger tb is a must and I found this . I was wondering what they ment by
    These Throttle Bodies will only fit 3.4L V6 with modified upper intake manifold
    Modified how?
    Also I just started looking around and thats the only one I have found. What about V8 take off's? If you know of other tb's for a 3.4 please let me know. Thanks
    Edit: its under induction. Hit the tb link at the top of the page and thats the one I am looking at.
    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
    The modified V6 intake manifold is a stock 3.4L V6 manifold that is basically cut across the front and then a box is fabricated for the manifold to hold the LT1 style throttle body. There are not too many of these manifolds out there. NuTek used to make them but they have stopped now. Some people are fabricating their own work, but it can get pricey.
      I'll give you details on what needs done. I'm waiting for my manifold to be finished port/polished then its off to get modified. I'm sure of what sensor and stuff I will need to switch though (TPS/IAC), any help on that Josh??
      Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
        TPS and IAC will be the same. No need for modification there. The one thing that does also have to be changed is the LT1 throttle cable. Simple fix.
          thanks let me know how it goes for ya Ben. And holy **** Josh, your car is damn impressive. [img]graemlins/bowdown.gif[/img]
            Thanks, lemme know if I can help in any way.
              I was also wondering about the modified intake to fit the LT1 throttle body. I have seen some pictures on how it was done, but obviously you would need a welder, and that is something I dont have. Viper98885, how much more power or throttle response did you recieve out of this modification. I am interested in it, because of the throttle response it may give. And obviously some increased breathing. I guess I should hold of on the cold air intake since this might occur. Thanks,
                You get quite a bit more power out of this manifold. If you have heads and cam, it's DEFINITELY worth the money. I threw on the BBK twin 58mm throttle body on mine when I did my engine rebuild and it added even more power. It's pretty amazing now.
                  That sounds good. I think this would go well with my 3" exhaust, and I have a cam at home, but I am thinking of holding off, until I can find a better cam. Was the throttle response better with yours. It sucks, I owned a carbed V8 automatic before this car, and I just got hooked on the throttle response. Now I have this choked 3.4 manual transmission, and I am missing my throttle response. Manuals dont have that spin up in the torque convertor to help with throttle response, everything is locked in place. Thanks,
                    Yeah, there is definitely an increase in throttle response...you are letting a WHOLE lot more air into the engine.
                      Ok, just wanted to double check. ;)
