Would this fit our cars? - FirebirdV6.com/CamaroV6.com Message Board
  • Would this fit our cars?
    http://www.customracer.com/camaro_induction.html
    scroll down to the throttle bodys. it is the BBK 80mm throttle body.
    will that fit a 2001 V6?
    2001 Black Camaro<br /><br /><br />I have no clue how i beat you.....maybe your car is slow.<br /><br />Whisper lid, SSRA, Pacesetter Headers, Carsound 3\" Cat, SLP Loudmouth, BMR strut brace, black ZR-1 rims, Xenon kit
    nope.. not easaly..
    ls1 intakes are centered.. ours are kinda offset..
      but wouldnt it just replace our throttle body?
        i dont even know what you meen by that.. its like this.. where the **'s are is where then inelt to the TB is on the lid..
        ls1
        3.8
        ours sit to the side a little..
          ur talking about where the inlet on the lid is...i know it is offset a but but so is our throttle body....so wouldnt this throttle body just replace the stock one?
            you would have to get a custom intake manifold too since that is also not centered and the TB connects to it. so the answer is no. the lid made for the v6 is fine though, dont worry about any small difference that package offers for the v8 guys.
              You'd have to look at the bolt patterns.
              Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
                It will not be a direct fit...Also out throttle bodies get coolant flowing into them from the intake manifold, whereas the LS1 TB you are looking at gets the coolant from lines that run in and out of the sides of the TB. It would not be worth the hassle IMO.
