Leaks and Sensors... still having problems after pacesetters - FirebirdV6.com/CamaroV6.com Message Board
  • Leaks and Sensors... still having problems after pacesetters
    ive had my headers on for about a month now. the first time i just used paper gaskets and soaked them. i could really tell that they were leaking though, so i yanked them back off and put some self cut rubber fiber gaskets on them with some ultra copper (permatex). there seem to be fewer leaks now but i can still hear it. it almost seems louder in the car than it does under the hood. im thinking it might be from where the header meets the y pipe so i put a few washers on there and torqued them down real tight but im still hearing it.
    my other problem is that im still getting an ses light from my o2 sensors. i have a sensor tester and i tested the two on the headers but neither one gave off any signal even after letting the car warm up. i guess it could have been a problem with the tester because my driver side sensor is brand new. less than 20 miles on it. i reset the computer and the light hasnt come on again yet but ive barely driven the car since, and im almost sure it will come back on.
    Visit My F-Body Page
    my driver side header leaks a very little bit where it meets the y pipe. mine sounds like a ticking or puttering. gets pretty annoying but the y pipe is welded and the bolts are tight so there's no point taking it off. I may try some exhaust wrap, but my problem isnt as bad as yours.
    My SES light actually went away after I got my cat back welded on. try some o2 sims
      Originally posted by MrCoffee:
      try some o2 sims
      yeah, i think it might come to that.
        oh and try tighting all your bolts after the car was run for a few minutes. common sense would tell you to wear gloves for this. but the aluminum becomes very flexable and you can actually tighten the bolts a few more turns. My shop did that with my header to the y-pipe bolts and they said they got it 4 turns tighter easily.
        it doesnt take long for the exhaust pipes to heat up so at idle for 5 or so min should do the trick. it might help that leak you're having.
          sure its not a leak in the EGR? thats where my leak is at.. anyone have any suggestions?
          99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
            I wrote a walk through about this, try searching it. By the way, you probably will need a new hose ($50 new-$25 used).
            <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
