2000 cat - FirebirdV6.com/CamaroV6.com Message Board
2000 cat
  • 2000 cat
    i need to replace my POS cat. i called summit to order one of the catcos, but they said they didn't make one for the 2000+. so i then called catco and they told me the same thing. i figure it must be one of the universal cats that i need. can anyone tell me which part # i need? i have stock pipes. thanks everyone.
    CTO-6006 or
    CTO-6007 ?????
    couldn't you just get a catco and have it custom fitted or something? i had a guy in Atl put in my old Firebird's Flowmaster setup for only 60, i'm sure you could just get someone like that to just put a new cat on a 2k, just a matter of fitting it... right?
    99 WS6
    13.25@104.97 - Lid + soon to be more other stock items ;D
    Originally posted by camaroextra
    tears are great lube, but its hard to get a girl to cry onto her own ***.
      well if that's all it takes then i could do that, but i've done the search, and i've seen some people with the 2.5" and then others have the 3.0" cat. so which one should i purchase for stock pipes?
        you need a universal catco with 3" inlet and 2.25" outlet w/out the AIR thing. plain and simple. i dont know the part number cause i bought a 3" in/out for my upgraded exhaust.
        2000 3.8 A4 Pewter Camaro
          thanks so much blldogg, i knew my stock wasn't 3 in and 3 out. thanks again.
            here's an update on the converter that i bought. got it from summitracing. model # CTO-6907
            at first i thought it was either model # CTO-6006 or CTO-6007. but those have air tubes and i didn't need a converter with an air tube. the CTO-6907 does not have an air tube, it does have 3" in and out pipes. cost around 70 bucks total and 37 for the install.
              thanks for the update. it will help me out a lot.
              \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
