I have longtubes for my 3.8. I am debating on which style of setup to go with. I will either run a 2.5" y pipe into a 3" exhaust setup, or a 2.5" y pipe into a 2" x pipe into 2" pipeing into 2.5" borla bullets cause they dont make the borla in 2" and then into 2" pipe the rest of the way back, now my question is, should i use cat converters or just use straight pipe, would i gain any et running just pipe in place of any cats or would i gain in et running cats? I will try a few runs at the track with the true duals dumping before the axle then after the axle and see which is best. I would like to hear some creative responses, yes or no on using cats or should i just run straight pipe rather than using any cats, which would be better in the 1/4? thanks
Which setup should i go with for my longtubes for my 3.8?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
I only know of one person with longtubes for the 3.8! :D
Anyways My opionion for what its worth!
I think going 2.5" into full 3" would be your best bet. I think it will sound good and give you great gains.
As far as the other setup I have no idea on how it would sound no one has done it that I know of! I don't think the gains over the system mentioned above would be worth the extra hassle!
2.5" into 3" [img]graemlins/thumbsup.gif[/img]
Second setup maybe better sound and mimimal gains over the 1st setup!
All I have to say is post pics. I would like to see what they look like. I'm guessing they are custome made. Who made them, how much did it cost.... just curious. I already have headers but I just wanted to see what other options are out there since there really aren't any. If you do have longtubes cool. [img]graemlins/thumbsup.gif[/img]<b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
I would also love to see what they look like. Also did you have them custom made or did you get it from some place?<a href=\"http://www.geocities.com/MotorCity/Street/6330/VicCamaro.html\" target=\"_blank\"><b>*1997 Silver Camaro A4/3.08*</b></a><br /><b>Best 1/4</b>(December 17, 2003)<br />Race weight: 3580lbs w/driver <br />RT: .396 1/4: 14.93 60\': 2.08 MPH: 89.73<br /><b>Mods</b><br />>Flowmaster 80 muffler (muffler only) >Homemade cold air with K&N 1000cfm cone filter >Trans-go Shift Kit >2400-2600 TCI converter<p><b>*1969 Camaro SS*</b><br />*502ci (92-octane pump gas)<br />*2-speed powerglide<br /><b>Best 1/4:</b>1.34 60ft 9.78@138.12mph (Aug 16, 2003)
They are custom made i have to do some modifying of my own on the drivers side, im still in the process of that, when i finish i will have pics, at first i thought i would have very bad restriction on drivers header but this guy who builds exhausts for race cars is helping me out with my headers i will have pics laterLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
