Ok i will have my longtubes on what i need to know is, do i have the x pipe directly attached to the headers or do i run pipe first off each header than have the x pipe attach to the pipe or does the x pipe directly attach to the headers? and at the end of the x pipe do i have my borla bullets directly at the end of the x pipe or do i run pipe directly after the x pipe then have the borla bullets on the pipe? thanks
Please help i need to know about x pipe thanks
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
option 2 to both your question... check out ls1.com and search for true duals. There will be lots of good pics for you.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
http://seppo.hopto.org/
Use 3" band clamps, if that is the size of the pipe and you should be ready to go. You can find them at NAPA etc. The bullet mufflers should be a little further down from the band clamps. My brother has longtubes on his T/A with a true duel exhaust (Dr. Gas system) so I know what it should look like. Try band clamps they are cheap, $10.<b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
band clampssorry dont know what that is
