Were should i put my cut out should i put it right after the cat ? or further back?
were to put cut out?
IMO the best place for the cutout is right before the rear axle. In place of the cat would just sound HORRIBLEThis revelation, is the death of ignorance...<br /><a href=\"http://www.quicktimeperformance.com\" target=\"_blank\">www.quicktimeperformance.com</a>
The whole point of a cut out is to run open headers at the track... so the only place to put it is before the cat!
To put it anywhere else makes little sense. The cat is a restriction in the exhaust system... why put it after a restriction but before another?
Yes it'll likely sound crappy, but who cares? YOu're at the track, you want numbers...
Will it help a stock engine n/a at the track? Not many do it, but the ones i've seen say it's helped... i'd say do it and it'll always be there for when you beef up your engine even if you've killed too much backpressure for the n/a setup... my 2cents.1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
Well the main reason you put it after the cat and not before is because without a little backpressure on near stock engines you won't gain anything from open headers so why run them? Keeping it after the cat creates enough backpressure to maintain decent low end torque.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
<blockquote>quote:</font><hr>Originally posted by ReodDai:
Well the main reason you put it after the cat and not before is because without a little backpressure on near stock engines you won't gain anything from open headers so why run them? Keeping it after the cat creates enough backpressure to maintain decent low end torque.<hr></blockquote>
Okay, so it becomes a question of what are the rest of your plans with the car. If you want to go stock for the long haul, then put it after I suppose... if you plan to cam/n2o/turbo/sc etc... put it before and do it right the first time [img]smile.gif[/img]1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
mines before the muffler and it definately helps but im considering doing one more towards the front this weekend just to try...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
Ok, well unless you decide to put it in place of the cat (which i wouldn't recommend to anyone), if you put it before the cat, you have to hack up your Y pipe collector. Theres not too many other places you can put it, unless you put it right before the rear axle. Most people get cutouts for the sound, and it will sound better there, and not rattle your whole interior too much. My friend dropped .2 seconds off his ET consistently with it opened. If you see better results before the cat then i'd like to know them.
Since mine is OBDI I am removing my cat converter completely and getting an electric cutout installed where my cat converter was -- but it wont hurt me because I am going to keep my 3" y-pipe back exhaust when I get my motor swap done [img]smile.gif[/img]Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
Not to be the so called "Car God" again. But Reoi you really shouldn't talk about things you don't know or fully understand. i.e. backpressure.
Do you know how much backpressure a 3.8L V6 needs in stock, or modified tune levels? Do you know how to measure backpressure?
Not to be rude, but it sounds to me like you are merely regurgitating some basic assumed philosophies about backpressure, that if you were to take a deeper look into would realize they are false presumptions.
Well, not to go into too much detail, but for a 3.8L V6. If you removed the cat. and the muffler. Only ran straight pipe and exhaust manifolds from the motor. The engine would have all the backpressure it needed.
There are two purposes of having a cut-out. Sound and performance.
Placing a cutout behind the cat. restricts both of these.
As far as sound goes, nothing sounds more awesome than open headers. But a great many people confuse too loud with sounding bad. Open Headers are indeed too loud (and I love it), but what they don't do is sound 'bad'. If its too loud for you, say so. No one is going to call you a "sissy" and actually mean it. Open headers creates a volume that can damage your hearing. You're smart to say its too loud. But don't misinterpret a bearable volume with "oh they sound horrible" The two are not synonamous. You need to learn to distinguish between the two before arriving at an opinion.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
werd. Sure, you might lose a COUPLE low end HP and low end Torque, BUT the gains you make up top are DEFINATELY worth it.
My buddy has a 14.4 second Integra GS-R. When he bought his header he had to run open header for a while until his "test pipe" came in. His car was a DOG off the line (more than usual), but the gains up top were unimaginable! He ran an S2000, and beat him by a car and a half running open header. So all that story is saying is, yes -- you will lose a couple down low, BUT the gains up top far exceed the tiny losses down low.Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
Before the cat. Just connect it to the collector then relocate the cat and run an O2 sim on the sensor.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
<blockquote>quote:</font><hr>Originally posted by KBeezy:
My buddy has a 14.4 second Integra GS-R. When he bought his header he had to run open header for a while until his "test pipe" came in. His car was a DOG off the line (more than usual), but the gains up top were unimaginable! He ran an S2000, and beat him by a car and a half running open header. So all that story is saying is, yes -- you will lose a couple down low, BUT the gains up top far exceed the tiny losses down low.<hr></blockquote>
Another misconception of backpressure. You do not lose low end torque...you only gain more top end horsepower.<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
<blockquote>quote:</font><hr>Originally posted by Bliggida:
Another misconception of backpressure. You do not lose low end torque...you only gain more top end horsepower.<hr></blockquote>
actually you DO lose low end torque, you should take your own advice. Its a very slight loss, but there is some low end torque loss from running a cutoutThis revelation, is the death of ignorance...<br /><a href=\"http://www.quicktimeperformance.com\" target=\"_blank\">www.quicktimeperformance.com</a>
