Heres the gasket, which holes should be blocked off for tb spacer to block coolant?
im working with someone else to make a tb spacer. which hole(s) in the gasket should be left in for the spacer in order to block coolant flow through the tb.
<blockquote>quote:</font><hr>Originally posted by AllTheGoodNamesAreGone: loochie.. I think the only one you want to block is the large one below the main opening..<hr></blockquote>
ok, got it. the large moon shaped hole beneath the main opening is the only one that needs to be blocked.
