I'll cut off the cat, clamp on a new pipe, but what do I do with all the sensors? Will I be throwing codes like crazy?
Probably Straight Piping It...
what year is your car? you most likely just how to replace the after the cat senser with a sim, thats all. this is how it is on 3.8s i dont know about 3.4's.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
Just get an O2 sim.
Originally posted by kristen:
you could alway just cut a new hole for the sensor and tap it.Matt
1998 Mystic Teal Camaro M5
just do what you said and get a sim. theres only 1 sensor to worry about and its right after that cat.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
sim is short for 02 simulator, makes the computer think the 02 sensor is working fine, thus no code-Brad
2000 V-Star Custom 1100
:rock:
i bought a sim from caspers and it work fine then boom the code came back and drove maybe 150 mile when the code came back up is this normal???2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-El:
i bought a sim from caspers and it work fine then boom the code came back and drove maybe 150 mile when the code came back up is this normal???Matt
i got this one item #104046 o2 sim cavalier & sunfire 1997-2002 is this the right one thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
i got this one item #104046 o2 sim cavalier & sunfire 1997-2002 is this the right one thanksMatt
yes im getting a p0420 why is that and what can i do about it? thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
