Interesting facts about FRA... - FirebirdV6.com/CamaroV6.com Message Board
  • Interesting facts about FRA...
    So I have a stock shaved lid free raim air, 3” pvc smooth bellow, and a K&N that needs a cleaning bad(talking like 8 months)
    Car is stock relatively speaking.
    Playing with hptuners, I started it up, car was roughly 3 hours cold. IAT read 96 degrees, before car was on, started it up, drove around got down to about 93ish cruising around 30 mph, then got to a bit of an open stretch and romped on it, and the IAT, worked its way from like 94-82, in a matter of like 1-2 seconds, maybe 1500 rpms.
    I know its kinda captain obvious, but we all know lower IAT temps will mean more power.
    Just a thought to consider. Another thing to get an idea of the air flow… when I run no filter and cruise with FRA, the car will surge, pretty bad down the road if I leave it in gear and have my foot off the gas. I assume its just excess air being moved in.
    Just a post for the people wondering if its worth doing.
    That really is interesting. What I would like to see is a comparison of the IATs to a non-FRA car. That would reveal quite a bit.
    1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
      I have a 97 so no FRA for me, my Incoming air temp to start one time was 95, then I did a WOT run to 78-80mph and the IAT went to 93. but then shut it down at about 80. It was a short wot run but IAT did go down.
      Is that the comparison you were looking for 98 3.8?
      http://www.bowtiev6.com/
        "if" I get really ambitious... I have a set of full stock lid, baffles, everything, slightly used paper filter(so I can go compeltely stock). I can do a comparison from full stock to my current setup
        Might do it one day in a week or two.
          Well not quite. Your intake setup is different from the 98-02. I was really looking for a comparison of FRA with stock.
          Edit: Clarification: Stock 98-02 temps
