throttle body spacers - FirebirdV6.com/CamaroV6.com Message Board
  • throttle body spacers
    Do they work?
    if they do witch is best, and is it worth buying?
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    I researched this a long time ago and put the information here. Not sure if it's still around but you can try to search for it. The general idea is this.... If it's a material like phenolic (sp) that will help block off heat from the TB it might show a small gain. But the fact remains that you really don't need more plenum volume on a stock ish motor.
      HBH is da man
        Found the old post
        http://www.camarov6.com/ubb/ultimate...5;t=006252;p=1
          ZZP SUCKS! I ordered it, and they sent me the wrong one, and now they wont send send me the right one! F ZZP!!! Don't order it from them!
          2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
            free mod:
            buy a new TB gasket. remove TB. clean TB coolant channel. fill with RTV silicone. let cure 24 hours.
            install TB. hot coolant now has nowhere to go in the TB.
            TB still makes contact with plenum so it is not the same as a 'spacer' but it is free.
            not suggested for daily drivers in northern (cold) climates.
            01 Firebird A4 3.42
            Powerdyne @ 6 PSI
            and other mods
