I am running stock exhaust manifolds, and have ordered the Magnaflow exhaust kit from RKSport part number #010915693 what high flow cat will work with this system I was looking at the Magnaflow-Direct Fit Converter part number MAG23466 or 23466 from car sound. will this fit and if not what will.
Help with Cat setup
I think the direct fit will fit with no welding at all. Just cut a slit in the appropriate place, where the slit is in the stock cat, so that it can slide in and be clamped. Not sure though.K&N CAI, Magnaflow High Flow Cat, Flowmaster American Thunder 2.5\" Cat-back exhaust w/ 40 series Muffler (single piped exit), Pacesetter Midlength Headers, TB Bypass.<br /><br />Vid of my 3.4 - <a href=\"http://media.putfile.com/Headers49\" target=\"_blank\">http://media.putfile.com/Headers49</a>
What High Flow Cat did you use?98 Camaro 3.8L black with T-Tops, K&N Air fliter, MSD Coil packs, More mods to come<br />web site <a href=\"http://www.wayug.com\" target=\"_blank\">www.wayug.com</a> \"are you down enough\"
