I'm not sure where this topic goes. But I think its here because it has to do with timing.
But has anyone done this mod before?? Does it have good improvements? What are the pros and cons? Will I need to use better gas?
This "mod" only does anything at startup and at WOT. Once the engine warms up the HO2 sensors control. The ambient air must also be above the "set" temperature of the resister, this "mod" will negatively impact you when it is cold outside.
Do a SEARCH, there is a lot more said about this "mod". Personally, I believe it to be a waste of time and money.
[ June 25, 2002: Message edited by: FirebirdGT ]</p>
<blockquote>quote:</font><hr>Originally posted by FirebirdGT: This "mod" only does anything at startup and at WOT. Once the engine warms up the HO2 sensors control. The ambient air must also be above the "set" temperature of the resister, this "mod" will negatively impact you when it is cold outside.
[ June 25, 2002: Message edited by: FirebirdGT ]<hr></blockquote>
But WOT is when we want the advanced timing, and if you buy a 8100K resistor it'll advance the timing far enough. For $0.99, its worth my trouble as a dragstrip only mod. However, the $25 RKSport/SLP charges is ridiculous!
Hey Guys.....I've done a search on this mod and I've seen people say to use a 4.7k or a 8.1k resistor. Based on everyone's experiences, which is the better resistor to use? I'm about to head over to radio shack now and pick up the resistor. Which one should I get?
<blockquote>quote:</font><hr>Originally posted by Dominic:
But WOT is when we want the advanced timing, and if you buy a 8100K resistor it'll advance the timing far enough. For $0.99, its worth my trouble as a dragstrip only mod. However, the $25 RKSport/SLP charges is ridiculous!<hr></blockquote>
I agree as a drag strip ONLY mod, and if you want to put it in and take it out again for daily driving that's your decision. It is NOT a street mod.
