I just got a cai and im trying to make an elbow for it, but i was wondering, what exactly whould i have to do to the elbow to connect the Air sensor? On the original setup there is something for it to plug into... what exactly should i do with my new rubber elbow?
Air Sensor Connection
Tags: None
yep, i know, but what about that piece you plug into on the stock intake- can this be purchased somewhere so that i can put it in the elbow? Anyone know?
I looked at the sensor in my old intake, and theres some sort of wireing... like two little prongs... in the harness that the sensor pluged into. So you couldnt just make a hole and stick it in because it wouldnt be plugging into those prongs- and they must do something right? I dunno much about this subject...
Just drill a hole for the sensor. I have the SLP CAI and it came with an elbow, but i didn't like the location for the sensor cause it required doing some strecthing of the wire. I plugged the old hole and drilled a new one and it fits nicely, and the wire isn't stretched one bit. No one can tell i drilled the hole either.
Good luck.<b>Matt</b><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=1\" target=\"_blank\">\'96 Camaro Z28 M6</a><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=3\" target=\"_blank\">\'96 Camaro M5</a>
<blockquote>quote:</font><hr>Originally posted by Loochy88:
I looked at the sensor in my old intake, and theres some sort of wireing... like two little prongs... in the harness that the sensor pluged into. So you couldnt just make a hole and stick it in because it wouldnt be plugging into those prongs- and they must do something right? I dunno much about this subject... <hr></blockquote>
you pull the whole sensor, terminal connectors and all, out of your existing induction system. unplug it, grip as much of the wiring connector as you can, and twist and rock back and forth until it comes out. then transfer to your new elbow.ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
<blockquote>quote:</font><hr>Originally posted by strange_trp:
you pull the whole sensor, terminal connectors and all, out of your existing induction system. unplug it, grip as much of the wiring connector as you can, and twist and rock back and forth until it comes out. then transfer to your new elbow.<hr></blockquote>
You've done this on the 96? Does it really just pull out? Thats things in there TIGHT! ohh well... i guess ill try.
yep, this thing definitely wont pull out... is there anywhere you can buy one? i dont want to have to cut it out.
Get pliers and grip the rubber gromet (NOT THE SENSOR) and PULL. It is definately in there TIGHT, but it WILL come out.<b>Matt</b><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=1\" target=\"_blank\">\'96 Camaro Z28 M6</a><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=3\" target=\"_blank\">\'96 Camaro M5</a>
I had a hard time getting it out too, so I cut the top of the rubber grommet and pushed the sensor in. When you cut the hole in the elbow, cut it small so it will fit tite when you push it back in the new elbow. If it is too loose, you can also RTV it, but should not have to if you do not cut the hole too large.97 Silver Bird<br />3.8 M5 Bone Stock Engine<br />15.528 @ 88.96 bone stock<br /><a href=\"http://www.fbodyenhancements.com/\" target=\"_blank\">www.fbodyenhancements.com/</a>
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...2 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
