Catalytic converter RATTLES! - FirebirdV6.com/CamaroV6.com Message Board
  • Catalytic converter RATTLES!
    Whenever i take off under low rpms... it rattles. i can take my hand and bang on my catalytic converter and it rattles. Is it just the casing (easily afro engineered by a clamp?) or the whole thing is just bad? Any quick fixes or things i can try? its annoying!! [img]graemlins/burnout.gif[/img]
    vRrOoOoOoOoOOooM
    where exaclty is it rattling? inside the cat itself, or around the pipe?
    2011 Camaro LS 6M, in black.
      It seems to be the casing. We have welded the pipes together in the back where they cross. When i take off in first the car is under load. We dont think that it is the heat shield. We dont know what exactly is making the noise?!?
      vRrOoOoOoOoOOooM
        my cat rattled when the element inside went bad and turned to pellets. i bet you need a new cat. you can get a 3in. catco for $50 plus shipping from Summit. ;)
        96 wht. firebird 5sd. rk sport headers,3in.catco, spintech catback,CAI,FRA,3.42/lsd 180*t-stat, centerforce dual friction clutch, ls1 driveshaft, polyurethane trans. mount.<br />01 blk. z28 m6, borla exht, lid, k<br />+n, sfc., chrome 18in. y2k c5 wheels.
          ON 95 AND NEWER CARS...ALL CARS, WITH UNDER 80KMI ON THEM, THE FACTORY WILL REPLACE THEM FOR FREE...CALL A DEALERSHIP AND ASK, THEY DON'T LIKE TO TELL THIS LITTLE SECRET!!!
            I had my Catco installed and it rattled like hell and the exaust shop said that the cat was bad and it was brand new.. Later that day I put my car on a lift and found out it was the o2 senser rattling because it came loose... Check your o2 after the cat first to make sure it is tight..
            Jeff ..
            1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
            2002 WS6 T/A.. Bolt ins..448rwhp
            2009 G8 GT.. Vararam intake, GXP axleback
            1998 Corvette.. Vararam intake, Ti axleback
            http://www.fquick.com/slow-v6
              My car has 107000 miles on it... its not under warranty any longer,,,, but ill try some of these approaches
              vRrOoOoOoOoOOooM
                what kind of exhaust setup do you have? if you have the Borla (or any 3-inch catback) it could be the I-pipe that goes from your cat to the muffler thats knocking up against the heat shield. and I've done everything i could to adjust it, weld it, bend it, or cushion it and it just keeps rattling. but it only does it at 1700 rpms. no more, no less. so i just learned to live with it.
                Project: _*_*_*Knight Ryder*_*_*_<p>2000 Black chevy camaro<br />3.8L v6, AT, t-tops<br />borla adj. catback, gutted cat converter w/O2 sim, whisper intake lid, K&N filter, SLP ram air kit, 160 thermo, JET stage 2 chip, eibach pro kit springs, 1LE aluminum driveshaft, custom red and black interior<br />14.95 seconds at 90mph in the 1/4 <br />So much Rice...So little time :D:D:D<p><a href=\"http://www.geocities.com\\camarokidd10\" target=\"_blank\">www.geocities.com\\camarokidd10</a>
                  I have stock everything from header to muffler and after that i have a flowmaster 80 series and some ta pipes. what youre saying sounds more like my problem, its justa nuisance and it makes my car sound like a heap when i take off! agh!
                  vRrOoOoOoOoOOooM
                    Gut It! [img]graemlins/burnout.gif[/img]
                    Teal 94 Camaro 3.4 Liter<br />Transgo stage 3 shiftkit, Shift module, corvette servo, SLP cold air induction,3.42 ring and pinion, Heavy Duty Posi LSD, Flowmaster exhaust, NX, blackouts
                      It could also be the heat shield on the cat. Maybe?
