What all would i need to get this to work on my 96 3.8 camaro? I would like to use the 98 tb and upper intake, is the 98 cable controlled like my 96 or is it computer controlled. I think the 99+ are computer controlled but im not sure. I would like to use a 98 tb so i can use the fast toys ram air [img]smile.gif[/img] do i need to use a different wiring harness? What would be the problems with putting a 98 upper intake on and tb? The 98 tb is straight out right? , or is it angled down like mine? thanks guys
Is it possible to use a 98 upper intake on a 96?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
is it??Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
im not sure but the fast toys ram air just cuts a hole near the radiator... the tb has nothing to do with it because it is still a angled tb only the diff is that its connected like a 99+, the 98 is still cable controled tho91 Eagle Talon Awd Turbo 5 speed FOR SALE 6000$<br />Looking for a Fiero GT<br /><a href=\"http://www.swdsm.net\" target=\"_blank\">www.swdsm.net</a>
For what it would cost to do that, might as well get a ram air hood and a nice ram air setup.
It almost certainly would match up on the engine though if your hellbent on trying it.
Only thing I would worry about would be hood clearance w/ the straight tb vs the angled.
but then, I'm really not sure as to how the tb of the 98 looks. I have a 2001, which is straight & computer controlled.
Go for the hood though. Might be a tad more expensive, but your car would look better with it. [img]smile.gif[/img]2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
<blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
...is the 98 cable controlled like my 96 or is it computer controlled. do i need to use a different wiring harness? The 98 tb is straight out right?<hr></blockquote>
The '98 is angled, and yes it is cable.
I don't know if the electrical hookups are the same, or not... I have a tps on the opposite side from the cable, and a maf sensor on the top of the tb, on my '98.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
the reason i dont get the ram air hood that allows for a ram air setup is because there is only one hood that has a ram air box and its teh ugly ultra z hood it looks fugly. well if the tb doesnt matter for the fast toys ram air then why did fast toys email me back and say we cant make a ram air kit for a 96 because of the angled tb, why isnt there a ram air for 96 besides the nasty ultra z crap hood and a homemade one?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
the ram air setup for 98+ puts a box in front of the radiator that forces more air into the air box (where the filter sits). pre-98's have the air filter down near the fender on the drivers side. you can't swap to the 98 style on a 96 because there isn't enough hood clearance for the air box to sit above the radiator, so you would end up having to get a new hood anyway to make that work.you can\'t get off if you don\'t get on
If i would get the new warbird ram air hood that looks like a ws6 hood would i have clearance to use the fast toys ram air?Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
phil at fasttoys says that there are more reasons why the fast toys ram air wont work on a 96 than besides hood clearanceLongtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
