wondering about LT1/LS1 MAF sensor - FirebirdV6.com/CamaroV6.com Message Board
  • wondering about LT1/LS1 MAF sensor
    Has anyone tried an LT1/LS1 (stock or otherwise) MAF sensor on our cars?
    How far off is it? In which direction, lean or rich?
    I had to put a '99 v6 sensor in my tb after I ported it, and it's still not quite right...
    Also with the bigger injectors, I run rich at idle and sometimes at part-throttle, with a little surge (which indicates the a/f is hunting).
    If the LT1/LS1 sensor is mostly accurate, but a little on the lean side, that would be perfect.
    I'm currently running a maft at max lean (12%) on the WOT setting, which is ok for drag racing, but it doesn't help at all for around town. And I can't get good results from running it lean on the Base setting, it throws everything off.
    I could always tweak the LS1 sensor into range with the maft, if it's not too far off.
    And get rid of the maf screen once and for all as a side benefit... [img]smile.gif[/img]
    Plus I think I could partially "hacksaw straighten" my angle tb, if the integral maf sensor wasn't needed... :D
    Things to think about. But it all hinges on the suitability of an LT1/LS1 type maf sensor upstream of the tb.
    edit - expanded to include LT1 sensors... [img]smile.gif[/img]
    [ April 23, 2003: Message edited by: John_D. ]</p>
    The LS1 sensor is pretty lean. I would think you would have a harder time tuning the LS1 sensor rather than the v6 one. I know for a fact that the slopes are different on the two sensor. At idle, I don't think they are that far off, my car idled ok with one. But at WOT it gets really lean.
    ZZP has a mini-afc that is calibrated for the LS1 sensor slope and might be what you need. Or you could use a regular mini-afc and MAFT+ together.
    DEE
    1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
      That's good feedback. Some of my interim searching a few minutes ago pointed me to some of the notes over in the diy forum too...
      I hadn't really thought about an LT1 sensor before, but I'm thinking that would be even better.
      I am trying to clean up the airflow around the sensor, and with the '98 angled down tb, going up to a center mounted lid, it's kinda ugly under there... So something that would help me straighten things out, and that read in a larger cross section of the tubing would be nice.
