i need to know if i should get a high flow cat with 3inch in and 3inch out, and a 3 inch i pipe, or if i should get 2.5inches?
96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
I went with a 3" in and out catco cat. Your inlet is already 3". As far as the I pipe, I got a 2.75" pipe off a Z28. I didn't feel any loss in performance.
Check my sig...I think this is the way to go on the 3.4's. I heard so much back and forth about 2.5 and 3 inches for the I pipe so I compromised.
1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
well im not 100 percent sure about getting a power adder, maybe just port and polished heads and a more aggressive cam, something similar to the SSM package, but cheaper [img]smile.gif[/img] i dont want to lose low end power, but then again, i want to gain top end as well. i guess ill go with 2.75 inch pipes. later on, im getting the RKsport headers, and a highflow cat. do they make cats with 2.75inch in and out?
EDIT: does this sound like a good idea? will i notice better quarter mile times?
[ April 15, 2002: Message edited by: Tyler ]</p>
If your able to get enough air in to take advantage of it, open exhaust would be the fastest for the quarter. Freeing up your exhaust will help your top end which you use while racing but may sacrifise a little low end which you use for every day driving. I didn't even feel much of a loss with my 3" pipe untill I got rid of the cat and got a 3" S pipe.
1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
<blockquote>quote:</font><hr>Originally posted by shortdog273:
Yes they are. The stock TA/SS/Z28 I Pipes are all mandrel bent. Navyblue is right about it necking down into a 2.5" going into the muffler.<hr></blockquote>
I can buy the I pipe out of an 2001 SS. Does getting a 2.75" S-pipe and the SS's I pipe ending into my 2.5"inlet dual 2.5" Dynomax muffler(the SS's I-pipe reduces to 2.5" when approaching the muffler,right?) sound like a good idea?
\'94 Firebird \"El Pichon\" 3.4L A4<br />Mods: CAI,NO CAT,NO EGR,<br />NO PCV,TB BYPASS,SLP IAT module,<br />Dynomax Super Turbo Muffler 2.5\" Dual,low temp stat, fan swtich<br /><a href=\"http://www.geocities.com/lando_pr\" target=\"_blank\">35 years of Firebird</a>
<blockquote>quote:</font><hr>Originally posted by lando_pr:
I can buy the I pipe out of an 2001 SS. Does getting a 2.75" S-pipe and the SS's I pipe ending into my 2.5"inlet dual 2.5" Dynomax muffler(the SS's I-pipe reduces to 2.5" when approaching the muffler,right?) sound like a good idea?<hr></blockquote>
That'll work. My Z28 I Pipe didn't come with the S bend for some odd reason.
no z28's have the s bend thats what i just found out, luckily before i decided to buy one
2001 SOM Camaro SS<p>Direct flo lid---Lakewood LCAs----Edelbrock Torque Arm-----Lous Short Stick---Dynomouth 3\" Exhaust---SLP Center Mount Exhaust---Poly tranny and torque arm mounts.<p>My site....http://community.webshots.com/album/49413018hRfdbP
<blockquote>quote:</font><hr>Originally posted by chevcamaro18: no z28's have the s bend thats what i just found out, luckily before i decided to buy one<hr></blockquote>
I didn't need an s pipe with my 93-95 z28 pipe. It came with a "semi-s" that worked perfectly. It comes straight down from the cat about 4 or 5 inches curves to the left for about 3 inches, and then straight back. Muffler shop added a small piece of straight pipe after the cat so that it would be long enough.
<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
How do your cars sound after the 3" modification? Does it sound a little deeper?
thanks
PV
Perry V.<br />\'97 Chameleon Bird w/ too many toys to list.<br /><a href=\"http://www.geocities.com/umvagia0\" target=\"_blank\">http://www.goecities.com/umvagia0</a>
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
