help with my borla exhuast - FirebirdV6.com/CamaroV6.com Message Board
  • help with my borla exhuast
    I used to have the Borla adjustable catback on my '02 v6 bird.. but i changed it awhile ago. I installed the borla myself, but then had it taken off, and had a different system welded on
    I'm planning to cut off the current system and put back on the borla but I'm confused about how to install it now. When I first installed it, no welding was involved.. where does the first piece of the I-pipe go... directly into the cat? or into the s-pipe piece that goes into the cat? I'm confused because it looks as if it will need to be welded even though it's a bolt on system
    does anyone have any good instructions with pics, or the real instructions? the ones I found online were ****ty and vague.
    thanks for the help
    \'02 firebird 5spd manual (pewter)<br />mods: whisper lid, spintech muffer with 3\" piping, strut tower brace, \"free ram air\", k&n filter, SLP CAI - next mods: jetchip stage II, lowering springs
    If I remember right, the straight pipe goes into the s-pipe and then to the cat. I remember the borla did'nt go directly in to the cat.
    If you're looking a pieces that need to be welded you may have a problem. We installed mine in the garage with just the clamp-on components.
    <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
      yeah but the S-pipe is welded to my current I-pipe.. I can cut it off but then what? will the borla I-pipe clamp into where the current I-pipe is cut off the S-pipe?
        I'd get a second opinion, but I think if you cut that section off, the Borla should clamp-on.
          anyone else?
            Why are you sticking the bola back on? Just curious. ;)
            2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
              Sell the Borla, buy an edelbrock, go buy a steak and a hooker
              <a href=\"http://members.cardomain.com/adamon6thstreet\" target=\"_blank\">1996 Firechicken</a><br /><b>15.19@91.61</b><br /><i>It Rocks Your Panties</i><p>Daily Driver: <a href=\"http://members.cardomain.com/pimpnon6thstreet\" target=\"_blank\">1990 Pontiac Trans Sport SE</a><br />Most recent mod: Mounted an Evan on the dashboard.
                Well if you are going that route forget borla nad eldebrook and have a Ravin Z-55 put on there.
