Hey guys, I went to go help my buddy with his SLP CAI install and noticed on the non-filter end there were some really small, fine metal "shavings". I didnt notice them with mine, maybe I didn't check. Should I have him sand paper down the inside...?
SLP CAI question...
You might want to take a fine metal file and clean-up the inside lip if there are small pieces of metal in there, or send it back to SLP and ask for a replacement. You DEFINITLY do not want any of that to end up getting sucked into the motor.
If you do file it down be sure to throughly clean the whole thing before install.<b>94 Firebird, 3.4 V6, Red, M5</b><br /> SLP CAI, Accel 8mm Superstock Wires, Bosch Platinum +4 Plugs, Borla Exhaust, BMR Strut Tower Brace, 180* Thermostat, B&M Ripper Shifter<br /> <a href=\"http://www.cardomain.com/id/94bird\" target=\"_blank\">http://www.cardomain.com/id/94bird</a>
Well I sprayed the inside of the intake with the water hose with pretty high pressure. Removed all of the dust or whatever is in the pipes and some of the loose stuff. Went over it again and some of the rough stuff is there but it isn't coming off if I rub it with my fingers. So I figure if spraying it with water doesn't loosen it, the air wont.
So anyone ordering a SLP CAI, might want to do that...get some of the metal stuff out of it. ;)
When i recieved my cold air package from SLP i realized that the inside of the tubing was "rough". So i brabbed some sand paper and started smoothening out the inside, then use an air compressor to air out the tube to get all shavings out.<a href=\"http://www.pbase.com/danny83/car_pix\" target=\"_blank\">http://www.pbase.com/danny83/root</a><br /><a href=\"http://community.webshots.com/user/ttopbird96\" target=\"_blank\">http://community.webshots.com/user/ttopbird96</a> [/URL]<br />00 NMB Formula M6<br />323.4HP, 336.5TQ<br />Lid, Filter, Cutout, all else stock :)<p>\"Let the modding begin!\"
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...2 hours ago
