I have installed the flowmaster 40 series about 3 weeks ago and everything was fine until couple of days ago. I put the kay in and it will not start it the first try, only the second. Is this normal or shound I have it checked?
Originally posted by Leviathan1994: your cat convertor may need to be replaced. other than that i have no idea
If it doesnt do it regularly then I would worry about it. if it does. A voltmeter can tell you loads. Also, when you turn the key if your voltage gauge drops a little like it usually does, then it most likely the starter solenoid. If it doesnt, then it is either the nuetral safety/clutch switch or the ignition switch. Good luck. ;)
