im sure this is a a stupid question but figured i should ask before i go and get this thing installed for a hundred bucks...
Is there ANY possibility that the new high flow cat will make my car sound more raspy or get a higher pitch?
i am really happy the way it sounds now but i HATE the rasp i get when i shift or am red lining it?
also, will there be any performance gain out of it or will it just be minimal?
thanks
!! Drive it like you stole it !!<br /><br />I believe forgiving them is gods function, our job is to arrange the meeting <br /><br /> <a href=\"http://www.azclubgp.com/garage.php?mode=viewgarage&u=202\" target=\"_blank\">2002 GTP 40th Anniversary Edition Sedan</a> <br />-------------<br />Mods:<br />3.4\" Pulley<br />rigged K&N Filter<br />14.3 et
yeah that is way too expensive, dont pay more than like 70 to have it put on. as for the sound issue, i think it chages the tone a little and you get a little more rasp at the top end since it flows better.
so it will sound higher?
**** that than, ill get a posi
