Im not sure if this has ever been atempted. There are two lines running into the throttle body from the cooling system. Their purpose is to keep the tb from freezing in the winter time and works with emissions to keep the tb cool while the motor is at normal tempiture. The water is the same temperature as the motor so its not any cooler. I routed the hose with the water flowing out of the motor to a small transmission cooler in the front bumper with an electric fan to cool the antifreeze, then routed the line back to the tb then back into the motor. These little 3 hp mods you dont really notice but every little bit helps right?
New throttle body mod
95 3.4 - Custom cold air with k&n, throttle body cooling system, 3.73, 3\" pipe after cat to raven with twin tips, All poly sway bushings, IAT resistor <br />Mods to come - Headers, high flow cat, high flow fuel rail, pump, and injectors.Tags: None
Sounds good! I'm gonna use the Dee throttle body spacer myself. Bypasses the coolant line. Aready purchased.
That sounds good though. [img]smile.gif[/img]<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
I found that bypassing the tb coolant line actually made it hotter than the engine. Try it and after your done driving, pop the hood and touch the tb. Just tryin to help ya out man.95 3.4 - Custom cold air with k&n, throttle body cooling system, 3.73, 3\" pipe after cat to raven with twin tips, All poly sway bushings, IAT resistor <br />Mods to come - Headers, high flow cat, high flow fuel rail, pump, and injectors.
how much and where did you guys purchase the tb spacerMy ride: <br /><a href=\"http://members.cardomain.com/youngdeezy\" target=\"_blank\">http://members.cardomain.com/youngdeezy</a><br />98 Firebird 3.8L A4<br />Mods:80 seires flow master muffler<br />dual exhaust 3\" pipes,whisper lid<br />k&N filter,3.42 gears and LSD, 180 thermostat, free ram air mod & 1/2\" raised air box + some apperance mods<br />1/4 mile 15.8 @ 85mph<p>I\'ll see you in the traffic...
