I was just wondering if it is possible to buy the SS style hood and use the SS ram air box that comes on the 97 SS engine and bolt it some how onto a 3.4L?. Cause i want a SS hood but i want it to be fuctional.
97 SS ram air box on 94 3.4L
R.I.P 1994 3.4L Black Camaro<br />K&N FIPK<br />Flowmaster Exhaust<br />Accel Wires and Plugs<br />Pioneer CD/MP3 Player 7400<br />4-Sony 6 1/2\" Explodes<br />2-12\" Kicker Comp VR<br />800 watt Rockford Fosgate Amp<p>Future Mods:<br />Performance Chip<br />MSD IgnitionTags: None
The only problem with the ram air on the 3.4s is that you don't have a MAF sensor, you only have the MAP (Manifold Absolute Pressure) sensor. The MAP uses the amount of vacuum in the intake manifold to assess the engine load.
If you add positive pressure (less vacuum) to the intake manifold (which a ram air would do), the MAP sensor would read that as a light load, and the PCM wouldn't react properly. When you went to full throttle, you may risk leaning the engine out way too much, and could do damage.
I don't know if the stock type SS hood could provide enough positive pressure to do damage, but you wouldn't be able to find out until the first time you stepped on it.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
I mean no direspect, but I have to disagree with some of what Guardsman said. I agree the 3.4 has a MAP, and I agree that increasing the air flow will reduce the vaccuum. But I disagree how the computer will react.
With the engine running, the lowest vacuum (highest pressure)reading is at WOT, and certainly the system will richen the mixture under that condition. If the mixture was leaned out at low vacuum, it would be richened at high vacuum. High vacuum is at idle, and it doen't make sense to me to richen at idle. Am I missing something?
I have not seen under the hood of an SS ram air Camaro, but I say if you can make it fit, go for it.1995 Camaro M5 3.4 Quasar Blue Metallic with T-tops.<br />K&N, Jet Stage II chip, Z28 exhaust, 1LE aluminum ds. Need more power!<br />Next: Auburn posi<br />1976 Pontiac Trans Am. Street driven. Has low compression 350 Chevy runs 12.81 @ 104, 1.73 60\'
I have a '93 3.4L V6 with functional ram air and have no problems with the MAP.
As far as that air box, it could be made to fit and would be pretty easy, but will take a little Home Depot work. Shouldn't be too bad though.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
LTNone hit it right on the head. Your greatest vacuum reading is at idle or part throttle cruzing where your engine is most efficient. Highest vacuum will be at greatest efficiency. But that is besides the point.1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
