U-Bend S-pipe? - FirebirdV6.com/CamaroV6.com Message Board
U-Bend S-pipe?
  • U-Bend S-pipe?
    I just read this in some posts. What exactly is this?
    Whisper Lid, SLP CAI, KN Filter, 3\" HiFlo Carsound Cat, full 3\" mandrel-bent piping, Flowmaster 80s, Casper O2 Sim, BM Tranny Cooler, Vigilante 3300 Torque Converter, Corvette Servo, 3.42 gears, SLP take-off LSD, Manual Fan Switch, & 160 Thermostat.
    That is where a few people are getting a JC Whitney U bend pipe, cutting it in half, slipping 1 half over and welding it back together to form an "S-Pipe"...........I've never actually seen or done it but from the posts I'd say it works pretty well as an S-Pipe
      Anyone got any pictures or the part number for this? Is it better than getting 2 45 deg pipes?
        I don't have any pictures, but I just did it about 2 weeks ago. It is actually a part from Jegs, all you do is cut it right in the middle of the U and then flip one end around so it looks like an S and weld that together.
        If you do a search you can find the part #. I can send you a link to the post I got my part # for but I'll have to get it to you later.
        It may or may not flow better but it only cost abot $25 as opposed to $50 or more for the 2 45s
        1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
          Ok. Thanks. I'd really appreciate a link to your post.
          ANyone else got any pictures?
            http://www.camarov6.com/cgi-bin/ulti...25&t=001750&p=
            This is the post I went off of and it worked great, if you have any questions feel free to email me. I basically did the cut and welded it at home then handed it to the muffler guy to put on the rest of the system. Saved a little labor
              ain't that a ***** i bought my two 45 degree mandrels from jcwhitney about a month ago arg. It looks like cutting that in half and flipping it would work way better
              1999 Firebird Black<br />A4 3.08 gears<br />Mods: Carbon Fiber Whisper Lid, Raised Air Box, K&N Air Filter, Direct Hits Ignition, Flowmaster American Thunder 3\", 160 Degree Hypertech Thermostat, SLP Fan Switch, 3\" High Flow Cat<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=273903\" target=\"_blank\">My car on Cardomain</a>
                So you got the
                CTO-2517 Catco cat and it already has the O2 fitting on it already?
                Can you get the U-pipe from summit also?
                  I did the U shape s-pipe thing to my exhaust and it works great. and its only 20 bucks.
                  40th Ann GTp 4door
                    I got the CATCO 6007 cause the other one was out of stock. I had to buy the cat from summit and the U-pipe from Jegs cause summit doesn't sell it.
                    I had the bung welded in from the old pipe.
