anyone ever smelt a foul fish like odor coming frmo their car? after drivng around for a while i can smell something like rotting fish coming from my car. it started the other day and it goes away after a while. its really really weird. i just tried to locate where the smell is coming from when i got home but it had disappeared. weird
fish smell????
it could be your cat, they smell real bad when they start to go outWolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
<blockquote>quote:</font><hr>Originally posted by wolf:
it could be your cat, they smell real bad when they start to go out<hr></blockquote>
Change the litter.*MATT* <p>98 Camaro SS #1767 A4<br />Artic White<br />Not stock...<p>Former car:<br />96 Firebird Y87 A4<br />Bright Red<br />Wasn\'t stock...
perhaps it smells more like sulphur? I could see sulphur and dead fish smelling kinda the same actually, anyways if its sulphur smelling your burning too lean I think?? maybe too rich? anyway reset your PCM, see if it goes away.. oh... have you recently done any mods to your car? and there may be a sensor going out, but its really not a big deal either way, and also the cat could be almost dead too, maybe its time to buy a hi flow =P
perhaps the reason the smell went away is b/c you got used to it??
edit: "maybe a sensor is going out" = maybe o2 sensor... or a couple otehrs I believe could cause this... I wrote the original post at 145 this morning, give me a break =P anyway sorry I couldnt be of more help
[ June 29, 2002: Message edited by: 93v6firebird ]</p>
Look under the hood too. Water leaks smell.<b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
