Im thinkin about gettin a high flow cat, What is the best. I was also thinkin about gettin another Borla XR1 and replacing the car with it. But if i do that where can i get a 3 inch s-pipe so i can run the O2 sensor? Which do u think would sound better. I want the borla b/c my car sounds liek a hopped up v8 all teh way through the rpm spectrum.
Borla XR1 replace cat?
I was also thinkin about gettin another Borla XR1 and replacing the car with it.It\'s a beautiful life<br /><a href=\"http://www.cardomain.com/ride/2035163\" target=\"_blank\">http://www.cardomain.com/ride/2035163</a>
If you're going to remove the cat, why would you want to hook up the O2 sensor?Matt
1998 Mystic Teal Camaro M5
