So I'm planning on putting a dynomax bullet muffler in the I-pipe. I have a 2.5" I-pipe and got a 2.5" i.d. bullet. Will I need some kind of adapter to put it in, or should the bullet muffler be able to slide over the I-pipe?
Bullet muffler
mufflers and cats are 'oversized' on the end collars to fit OVER whatever ID pipe size they are...so yes...a 2.5" muffler will slip over 2.5 inch piping.
mark your cut lines accordingly.
my cat wasnt oversized on the end collars\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
On the other hand, would it sound better to just put it in place of the cat, since there are no emissions in Wisconsin. I want it to be louder than just my flowmaster system and I don't want the rasp or popping. I've read that getting rid of the cat makes it more raspy. Will the bullet take it back to the same raspiness, or still make it have and even tone all the way through the powerband?
I've heard of it being put in place of the cat, but I don't know if it will sound better. I don't see why it wouldn't cut out the rasp and pops just as it would if it were in the I-pipe. If you wanna run no cat, it may be better to put the bullet in the I-pipe and just run a straight pipe in palce of the cat. Do some checking on that before you take action, though, I'm a novice with exhaust.K&N CAI, Magnaflow High Flow Cat, Flowmaster American Thunder 2.5\" Cat-back exhaust w/ 40 series Muffler (single piped exit), Pacesetter Midlength Headers, TB Bypass.<br /><br />Vid of my 3.4 - <a href=\"http://media.putfile.com/Headers49\" target=\"_blank\">http://media.putfile.com/Headers49</a>
