people with the big dee space look inside - FirebirdV6.com/CamaroV6.com Message Board
  • people with the big dee space look inside
    ok i have he spacer on. i have a 97 model car. how did you get the idle back to normal. do i need to bend anything.. mine is idling pretty high..
    97 CAMARO RS<br />12.9@103mph<br />best 60ft..1.9 ( on street tires)<br /> 1.7 (on gas)<br />turbo supra 12.5@119mph (street tires)<br />new times to come sporting the sp63gt
    On the black bracket you will see where it comes down in the front to the left. you need to bend that straight to achieve normal idle. Thats what I did works fine now. Unless there is some way to adjust the cable?
    1997 30th Anniversary A4 w/ some mods
      Mike, let me know if that corrected the problem. Also, if either of you have a pic, I would appreciate it. Seems some of the 95-98 cars are doing this.
      DEE
      1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
        ok i'm going to have a look tommorow. it fits like a charm, just have to fix the idle. i'll post pics tommorow
          well i got my car to idle at exactly 1000 rpms. it was very simple. i didn't have to bend anything. i just used the other mounting hole on the throttle cable mounting plate. (the hole that goesinto the left side of the tb)
