We all know 4.7K is about 32deg. But how many deg is it if one doesn't have one? Mine has been sitting in the basement for some time now. Car is pulling hard as usuall. I still spin into 2nd. Definitely didn't loose any power. I probably didn't gain any either. This is not a mod. I just broke it. So I'm wondering what the PCM is thinking.
IAT riddle
You'll eventually get an SES, but I've run with mine unplugged before. I have noticed no drawbacks other than the SES by running without one.2002 5-spd NBM Camaro
Details: www.1lev6.com
The IAT output signal is used with the MAF output signal by the PCM during cold starts and at WOT - ONLY. All other times the heated O2 sensors control everything.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
<blockquote>quote:</font><hr>Originally posted by FirebirdGT:
The IAT output signal is used with the MAF output signal by the PCM during cold starts and at WOT - ONLY. All other times the heated O2 sensors control everything.<hr></blockquote>
Hmmmm I was WOT alot that day. Today I lost the whole wire to the IAT sensor. hehe I found it in between some pipes so I retaped the wire and I taped the sensor into the intake. I should probably get a new one someday.
