D@*n header gaskets again - FirebirdV6.com/CamaroV6.com Message Board
  • D@*n header gaskets again
    well i just blew my third set of header gasktets today. Yay time to get some bloody knuckles again. Does anyone know of any better gaskets out there other then felpro cause these gaskets blow literaly. Also i found these http://store.summitracing.com/defaul...=egnsearch.asp
    1 would these work on my 3.4 and second would these help my gaskets from blowing every 6 months.
    95 camaro 3.4 &lt; Jc whitney Exhaust, Chrome intake stage 2, Rk sport headers, msd dis-4, 160*thermo, Jet stage 2 chip, black racing stripes.<br /><br />91 Camaro rs 5.0 tbi gone but not forgoten
    how do you tell when your gaskets blow?
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      use 88 v6 fiero exhaust gasgets, they are made better
        well i have that nice loud tick noise coming from driver side headers. The time the blew in the winter i could see puffs of smoke come up from them i can't see that now but yea....
        Thanks wolf i'll look into those.
        Does anyone know if those bolts will work.
          well dont use Fel-Pro anymore thats for sure, i had them on mine well now i have one fel pro and one pacesetter in cuz no one wants to do the passenger side gasket for cheap. So kinda screwed there, but i know OEM gaskets should work for 3.8L but im not sure bout the 3.4L OEM gaskets.
          99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
            mine tick, but its not really loud, and i dont have any problems at all.. do you think mine could be bad or i have a leak somewhere?
            dont headers tick on there own anyways, a little?
            Dave:
              the felpro's blew because they are stock sized replacements, not sized correctly for aftermarket headers. I think 95bat is using the fiero gaskets and hasn't had a problem with them.
              95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
                oh it's not a slight tick it's nice and loud you would know if you gaskets were blown. check around your egr valve thats where i usualy get most of my problems.
                How about those bolts will they work on my 3.4?
                  opps i just notice that the link for the bolts is incorrect this is the ones i meant
                    how about these http://store.summitracing.com/defaul...=egnsearch.asp
                    I want to replace my bolts cause i'm just using standard ones from a lowes and yea i usualy break a few when replacing gaskets.
                    Also another question what would happen if I deleted the erg valve. I mean I always had problems with it leaking there i was thinking of just welding a plate to the headers and just bolting something to the intake.
                      the stg-8900 (the first link) should do the job. The thread pitch is correct. If it's for the 2.8L engine, it should fit your car.
                      1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
                        what about egr valve delete does anyone knows the cons and pros of doing this. I heard you lose gas mpg but is it a significan't amount?
                          y bother, just leave it on there. If you are in a state that does emissions, you need to have it to pass inspection.
                            ok well now none of the local part stores carry the fiero gaskets. where did you guys get yours from do i need to get them from the dealership?
