i seen this stuff at autozone its called flex pipe i believe, well you can take it and bend it any direction you want, can i use this for making my exhaust setup? can this stuff be welded? if it cant be welded and it can only be clamped do you think a clamp will stop it from leaking? will this stuff be ok for my true dual setup it would be much easier connecting the x pipe with this flex pipe
can you use flex pipe for making exhaust system can it be welded?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,Tags: None
I always wanted a krinkle-cut exhaust [img]smile.gif[/img]
Because its flexible, it doesn't tend to stay where you put it. It can shake loose and pop out of flanges, I'm sure it can be welded but god knows how it will flow.
I would never use it.2002 5-spd NBM Camaro
Details: www.1lev6.com
