homemade ramair - FirebirdV6.com/CamaroV6.com Message Board
homemade ramair
  • homemade ramair
    i have a 3in pipe that runs from the engine intake that goes down under the car and is curved at the bottum toward the front of the car with a cone filter facing straight ahead will this work
    cold air intake <br />80 series flowmaster<br />no cat (straight pipe)<br />rebel flag
    Only problem with that is that the filter will need to be cleaned a lot more often but you will be getting colder air.
      so the filter is like less then a foot off the ground?
      Your climate might be different but in FL, you are asking your motor to suck up a healthy puddle of water and hydrolock the motor.
        ok i took the cone filter off and replaced it with a funnel type thing so it would ketch the air and i cut out the cotton stuff from my old filter and placed it ofer the end of the pipe were the rubber elbo connects i was wounderin if it would work as ram air it looks cool and i dont c y it wouldnt
          so youre saying you put a put some filter material around the end of the tube, and then shoved a funnel on over it? i hope you secured that paper really well, or youre going to be sucking it right up.
          sounds also like you dont have a lot of surface area on the filtering area. youre probably getting less air than stock if this is the case.
          pics?
          Visit My F-Body Page
            Ok, let me just put my 2 cents in about ram air. Ram air does not exist. Just do a good cold air and you will be good. ram air is good marketing, You will never get enough positive pressure to give you gains over a standard cold air intake.
              yeah unless youre going 130+mph all the time, a ram air setup isnt worth the cash over a good CAI.
              Follow me!
              Or this
                lets clarify the differece between RAMAIR & COLDAIR.
                cause i've seen many different opinions/products
                  ram air needs to be a pretty straight shot into the throttle body as the bends will slow it down. 3 or 4 bends in the nitake tube will almost negate the effect, even at high speeds i would think. its pretty much just as good as cai at any low speed.
                    The truth about Ram Air:
                    Have you ever stuck you hand out of the window at highway speed and felt the force of the wind against your hand? What you're feeling is called stagnation pressure, a phnomenon caused my the increase in local air pressure when moving air is brought to a stop. Mathmatically, this is expessed as:
                    Ps = Po + 1/2 * (air density) * (Velocity)^2
                    At 60 mph in a standard atmosphere, this amounts to a preassure increase of 0.07 psi. This goes to 0.1 psi at 75 mph and to 0.17 psi at 100 mph.
                    True, this doesn't sound like much (and it won't exactly take the place of a powerdyne any time soon), but it is "free" and does help a little to overcome intake restrictions by 'ramming' air down the engine's throut.
                    That all said, would I spend a lot of time, money, or effort to rig up the perfect "ram air" intake? Naaaaaaa. :D
                    1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
                      for what its worth...
                      before I had free ram air and ran no filter, if cardrove fine...
                      after free ram air and when I ran no air filter... if I just cruised down teh road, not speeding up ar slowing down. The car will surge and jerk, my best thought is maybe air being blown over the MAF while the throttle is constant.
                      just my $0.02...
                        ram air probably works at higher speeds only
                          are you sure about that?
                          I think it works at a stop.
                            what about reverse..
                            doesnt ram air help you 60ft times too?
                            1996 Dark Green V-6 auto. few mods.<br />previous rides:<br />1989 turbo 5 speed dodge caravan (18 PSI, 3\" exhuast,intercooled blah blah)<br />1989 Mustang GT (11.72 @118 many many mods, blown engine a.t.m. :-( )
                                6 days ago
