I was talking to my dad about how I can get more power. We're going to P&P the intake manifolds. He thought of making a plate for the throttle body to fit. Could this affect my idle? Or would the idle control make up for it?
5.7L TB on a 3.4?
5.7L TB on a 3.4?
\'94 Pontiac Firebird 3.4<p>MODS<br />Custom CAI, by pass cat,<p>soon to come<br />SLP CAI, sweet thunder exhaust, 1.25 lowering springs, 3 pt sub frame connectors, traction bar, port & polished heads & intake manifold, Headers, strut tower bar, ram air hood, SLP rims 18 in, tires? any suggestions? E-mail at firebird1206@aol.comTags: None
I think you have a great idea with the plate, although would it be easier to acctually bore the upper manifold to fit the 5.7 TB in it? I'm sure you could find an engine shop to do it fairly cheap as well.1995 Camaro 3.4L V6 Hurst shifter, Hypertech 160 Deg T-stat, K&N FIPK, Eibach Prokit Springs, Dynomax Cat back exhaust,Interested in any mods to speed up the car!!!
we are trying too get an intake ready for production right now that will have the design you want. tiago and i are both running this design and it works very well. all you have too do is get the tb, get the upper intake that is modified for the tb, gaskets, and an lt1 style throttle cable. the only fabbing that needs too be done is for the bracket for the cable. we will be selling these soon if you are interested!!boost, you got it???
I'm deffinatly interested. Seeing that I don't have much for money, what would it cost?1995 Camaro 3.4L V6 Hurst shifter, Hypertech 160 Deg T-stat, K&N FIPK, Eibach Prokit Springs, Dynomax Cat back exhaust,Interested in any mods to speed up the car!!!
Making a plate without boring out the upper intake manifold would be kind of pointless I would think, it'd be no different then stock...as.... you'll let more air get to the manifold because of the bigger throttle body, but once it gets to where it bottlenecks to the stock upper intake manifold, the same result as stock would happen?
Am I right? Just trying to visualize this in my head, I have never actually seen a 3.4 upper manifold.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
